A Guide on installing your own remote central locking in under 20 minutes
Note this is for replacing the defunked genuine Ni$$san unit with a Warlock KG400 kit.
This was all done on my 2001 GUII, 3.0ltr. Different models and engines may differ.
All was done directly where the original wireless remote controller sits. Under the LHS of the dash, to the right of the glove box.
No need to run any other wire to anywhere else. Also the locks are positive triggered too. The kit I bought, and assuming all are like this, has the wiring for both positive and negative triggers.
So the coloured wires to look out for are :
- Indicator output : Green/ Red
- Indicator output : Green / Yellow
- 12V feed : White / Red (Thicker wire than the others)
- Door Lock output : Light Blue (Thicker wire than the others)
- Door Unlock output : Light Blue / Red (Thicker wire than the others)
The kit you buy will have instructions telling you what their wires are for so that part is real easy. It was working it out on the truck end, but I got it and it works a treat.
So all can be done and installed in the one spot and after I worked out the wiring, you could do this in under 20minutes, easy.
Now I just have to figure out how to learn the spare remote. The instructions I have are in Klingon I reckon.
Hope this helps anyone.
All I want to do now is work out what I can use the trunk release button for. Remote switching flood lamps maybe?
Re: A Guide on installing your own remote central locking in under 20 minutes
What info do you need mate?
I tapped that app...
