dom14
Yeah mate. You were right about T pieces being there for a reason. And I was wrong about heater core coolant entry having a four way valve as above anyway. I've corrected that in a post after that, and I'm just about to post all the details, pictures from the factory manual and Gregory's manual about it.
T joints were put there 'cos there's no other way to do it. Series setup would've cut the coolant flow to LPG converter or heater core or both depending on which one I plumb the coolant entry first. When the tap inside the heater core is shut by sliding the dashboard heater slider to cold, that will cut the coolant flow completely, which won't be a good thing for the LPG converter to start with.(and may even create cavitation air bubbles on the coolant return line to the engine block, which would "help" to create cracks in the cylinder head in no time, so it's definitely a bad idea)
I will replace the thermostat with a brand new stock one (76 degrees) to start with and see how it goes, 'cos the current one is opening up at around 70 degrees or bit less, which I think the major reason for low temperature. If the new one still yields low temperature then I will install a one bit higher, like 80 degrees or so.
I will also replace T pieces with Y pieces soon. I've been told it's better for the flow and helps reduce cavitation(air bubbles inside coolant).
Dom
