How big of an intercooler do I need and can you go to big ? It is a Td42 with a Denco turbo I can not tell you what it is has a 2.5 inch exhaust which I want to upgrade eventually to a 3 inch
I’d be a mechanical nuffy FP mate but from what i understand of diesels you could in theory never go too big either end?
Coldest huge moist air into the old gal, coolest efficient huge tuned air out of the exhaust?
Similar, USA Top fuelers (comp drag beasts) book time/meets on Western Australia’s Kwinana race complex-strip looking for that crisp Indian Ocean Record Breaking Doctor in season ;-)
Lot use nom 600x300x76mm, with underslug 9 or 10" spal fan, TMIC or FMIC
You definitely don't want to too thick as it would loose its efficiency. I wouldn't go any thicker than say 90-100mm
Is it possible to run a ZD30 intercooler? would it be better then no cooler at all or would it slow the airflow and make it worse
how about one out the front ! . I have an out the front one on mine . There would be no way in hell I would ever have one on top of a hot engine again!
the best thing I have ever done . !! easier to do an oil change . to boot ! I did some temperature checking under bonnet and it gets way to hot under there .
i have thought about a front mount but i really dont have much room there with the ac condenser and i have a thermo fan it the front for the ac when its not moving.
ive been thinking zd30 intercooler (because i have one) and strap a small thermo fan to the back of it
front mount will fit but you'd trim the back side of the grill a fair bit.
id be doing that 3" exhaust before i did another thing mate. How much boost are you running? have you had it Dyno Tunes? if so what is the output? is it intercooled now?
Yeah get rid of the thermo fan and the bonnet brace and there is a heap of room mate.
The thermo fan is only used to keep the ac cooler whilst stationary but even still mine works fine without it.
Slightly annoying trying to get your bonnet to latch on sometimes but it's worth it lol
