https://youtu.be/X9FtPPSTk4E
Heres a link to hear sound
IS it only under hard acceleration or load? Or does it do it at the same revs when cruising?
It does it more when just cruising light acceleration. If I put my foot down it stops
Went to mechanic today he said could be cutch fan hub it did have a little play in it ,
That what gqtdauto said to
I’ll find out Friday when Intercooler and clutch fan comes in thanks
Mate that's one weird arse scream it almost sounds like those screaming goats , I'm not confident it's the fan clutch and thinking more turbo , my idler rollers for the fan belt occasionally one of them makes a noise but not like that .
I see what you mean about it doing it while under acceleration but also backing off .
Mate I’ve changed turbo , intercooler , clutch fan I’m starting to think is it a pulley belt alternator
I’ve replaced the tensioner pulley 50000kms Ago
I just can’t put my finger on the problem
Worth checking I suppose it doesn't sound like an alternator but I've been caught before , is it still putting out 14.3-4 volts
Wondering if it's possible to disconnect the fan belts and go for a quick spin to see if the noise is still there , maybe someone here knows if that's possible without causing damage .
If its alternator, it may change in pitch under load. Maybe turn the lights and aircon on and fond see if the pitch change. Idler pulley?
