I will keep my eye out for you. I am based in Halls Head. :)
Checked out the MAF this morning and found it to be just placed in and not bolted in, looks like the top hole has been striped so i will need to tap it out to 6mm and bolt it in properly. I am not taking chances and will take the intake pipe off to ensure I dont get any pieces of plastic through the engine so it will have to wait until Saturday :(
I'm going to change the gearbox fluid to full syn at the same time and hope it makes a difference to the way it changes and runs.
The MAF did vary on the multimeter though and seems to be throwing correct voltage from what I've researched, it idles at 2.1v (EGR mod done) and revs to just over 3v at 3000rpm (can't remember exactly now)
I did find and play with the needle valve today too which probably isn't a good idea since I'm having dramas anyway, but I can't help but fiddle with stuff I really shouldn't. It seems to have a big flat spot around 3000rpm now but I'm not sure if I caused it this morning with the needle valve or whether it has been there all along - I really am my own worse enemy........
I will change the fuel filter and put the needle valve back to where it was, get the MAF bolted up correctly, do the gearbox service then see what happens from there :)
Cheers for the help guys.
Unplug the chip and then re assess I think.
As for the needle valve. We know your boost level is good, wind the needle valve right in while the engine is at idle, the arm on the turbo actuator should go up. Then slowly open the needle valve, until the arm drops maybe 5-10mm, 'ish, then go for a drive. If the boost rises real slow upon acceleration, the needle valve is open too much. You want the boost to rise quick and hit the max boost and stop. If it bounces a little past then settles. That fine. Alos at 100kph you would want around 12psi whilst cruising along the flat. if its lower and you want to raise this level, close off the needle valve a little. Vice versa if you want to lower it.
