Definitely worth a call to the insurance company. A couple of hundred is better than 30k.
I've just temporarily removed my 2nd row seats for a trip to the NT in May. They weigh 26 kg each so it's a big weight saving and an ideal spot to load any heavy items low down and forward of the rear axle.
The 3rd row seats were temporarily removed 10 years ago to make way for drawers.
I removed my second row seats for a 9 week trip up to Cape York and across Carpentaria last year, used the space for my fridge and an esky.
Attachment 78048
Attachment 78049
@TPC could you tell me or do you have pics of how you secured the base to the floor?
That looks a lot like what I was thinking of doing.
This photo shows underneath the base I put in, I used the seat mounting points to screw the base down. The bolts needed are 12mm x 1.25, 70mm on the rear and 45mm on the front.
I have 45mm timber spacers that recess into where the rear seat lock down loops were, had to cut the carpet to make them fit in and 20mm ply for spacers at the front.
The front edge has a length of 45 x 90mm but this is not needed.
Attachment 78050
I recessed the bolts so they didn't hit the bottom of the fridge or esky, the front bolts go in on an angle, makes it a pita to get the holes right.
Attachment 78051
The measurements below are not correct for the bolt hole spacing, I would suggest getting the bolts and screwing them into the holes to make it easier to measure spacing.
I had to elongate the holes to make it fit after drilling in wrong places.
Attachment 78052
Well thank you indeed @TPC
That is going to save me a lot of fiddling around.
I will get that set up over the next week.
I had a platform like that in mine for a while, but found it didn't really give me much more space despite the seat now being removed. I had a cabinet system - anyway, am now looking at a system that takes up maybe only half the rear seat - @MudRunnerTD has a couple of modified second row seat frames for mis 'darkness only beast' and they might be of interest - they bolt into the seat mounts as well and tip forward etc - look very clever.
I have only removed the seat behind the driver to mount my Engel on a platfloor.
takes 5 mins to change it back. I only have a half barrier, but it suits my needs down to the ground'
When I was working I got a spare set on hinges from the guy from Two\Zone so the lid would hinge the other way..
no need for 0verpriced drop down thingies , what even did we do with out them, have we shrunk
as a nation over the years like global warming, Aslo had the Transit bag restitched to suit, again works for me
