hand held gen bracket and gen solenoid in approx position.
This is a broken one I replaced with a aftermarket one.
Also in approx same location.
Thanks Robo, the actuators that I have look nothing like that and when mounted internally in the door they conflict with the window mechanism.
What brand did you end up getting? I may have to shop around by the looks of it as I now have central locking for the front 2 doors but still have to do the rear manually which isn't a problem until you have ballance a child in your arms.
Thanks for your help.
sorry no pics but if you look down the snipper hole i mounted it right down the bottom of the door facing up with the rod from the motor pushing and pulling on the snipper rod just above the lock
Post up an intro first, follow forum policy please bro.
cheers
4 door kit.
2 door kit.
Individual parts also available.
Jaycar and JB's
This type of actuator is what I replaced the broken gen nissan 1 with.
Pic is stand alone kit for a car that doesn't have c/lock in the first place.
Can also be hooked to work with alarm systems.
