I've got a Series 1 TB45 GU, the drivers side drag link ball joint is worn and needs replacing. Are the ball joints the same part as the tie rod ends?
I expect that they are. You will need to get the correct Thea's direction though. Left or right?
I would stick with genuine though so hit up Patrolapart.
Must be different on the TB45, on my ZD30 patrol the drag link ends are not replaceable, you have to change the whole thing.
That is interesting Mark, I wonder why Nissan would make them different? I just replaced mine and you definitely can't change the ends.
