Y62 Towbar plug and Loom Install
OK so I have fitted a second hand towbar to The62 in anticipation of fitting a Steel Rear bar in the future.
Installing a Trailer plug is a breeze in these and rather than reinventing the wheel I opted for an OEM factory Plug and Play loom kit.
So here is the factory Loom part number and bar code
http://www.nissanpatrol.com.au/forum...2022/01/44.jpg
These instructions are very important. Especially the strip out and refit order.
http://www.nissanpatrol.com.au/forum...2022/01/45.jpg
http://www.nissanpatrol.com.au/forum...2022/01/46.jpg
http://www.nissanpatrol.com.au/forum...2022/01/47.jpg
http://www.nissanpatrol.com.au/forum...2022/01/48.jpg
http://www.nissanpatrol.com.au/forum...2022/01/49.jpg
http://www.nissanpatrol.com.au/forum...2022/01/50.jpg
http://www.nissanpatrol.com.au/forum...2022/01/51.jpg
http://www.nissanpatrol.com.au/forum...2022/01/52.jpg
http://www.nissanpatrol.com.au/forum...2022/01/53.jpg
http://www.nissanpatrol.com.au/forum...2022/01/54.jpg
http://www.nissanpatrol.com.au/forum...2022/01/55.jpg
The instructions missed this part but this whole side trim really does need to come out.
You can see the clips in the photos that you need to pop. Release rhe front from the rear passenger Door and the rear edge from the back. Then get into the back and grip the cup holder area and give it a big pull like your trying to crack a whip. Don't just hang off it. Shock Pull and it will come off.
http://www.nissanpatrol.com.au/forum...2022/01/56.jpg
http://www.nissanpatrol.com.au/forum...2022/01/57.jpg
http://www.nissanpatrol.com.au/forum...2022/01/58.jpg
Here is the convenient Factory loom plug waiting for you.
http://www.nissanpatrol.com.au/forum...2022/01/59.jpg
Plug and Play
http://www.nissanpatrol.com.au/forum...2022/01/60.jpg
The loom is EXACTLY the right length. No room for nicely laying it around. You have not got an extra 10mm!
Here is the grommet you remove ans replace with the loom grommet.
http://www.nissanpatrol.com.au/forum...2022/01/61.jpg
http://www.nissanpatrol.com.au/forum...2022/01/62.jpg
Pretty nice to see the sound deadening
http://www.nissanpatrol.com.au/forum...2022/01/63.jpg
And here is the factory Sub Woofer in the TIL
http://www.nissanpatrol.com.au/forum...2022/01/64.jpg
Ok. Back to the top now and take note of the reverse order install of the rear panels you have removed for this job.
I hope this helped
#The62
