Hang in there Dazzler mate. Keep that sabersaw away from the leg a little bit more.
The way things are , I'd try and keep away from hospitals for the moment.
This no rego sticker BS. The paperwork for Mrs mudsane's new car didn't arrive so the rego nearly ran out. I know it is easy to check, but I recommend having the rego number and date due of each family members' vehicles posted on the fridge.
Had a Kidney Stone removed Surgically today.... 8 now have a stent in my urinary tract for 2 weeks.. I Farrrking Hate the Stent!!! MOFO.
F@#king washing machine.
Been coming up with a error, but it's not a fault. Something about too much detergent and the machine will fix it itself. Bullshit have tried everything, no faults with no load or detergent, put one clean item with no detergent and fault comes back.
If it was broken I wouldn't have an issue in getting another one, but it works sort of.
Can't even go to the shops will have to purchase something online with click and collect.
Could be a loose connector or a burnt out micro switch. I might pay to open it up and have a quick squiz. We had a similar problem and I only found the micro switch when I was wrecking the machine. DOH!
They're all open for click n collect.
But yeah , you can't physically go in and browse.
Have you tried unplugging for 10 minutes (disconnecting pwr) forced reset of computer?
Worked with my reverse cycle A/C after pwr surge.
Maybe flush water thru where soap goes in / clean lint thingo.
Do clean water only cycle maybe, guess you have taken the hose to it anyway... Would be tempted to take panel off and have casual look around, check tub balance restraint.
