7 Attachment(s)
92 GQ Y60 passenger side sliding window water leak
So with the wet weather around ive noticed that my passenger side sliding window has a small leak which seams to be coming from where the window latch is located, im not sure if its due to the type of seal thats in place or if its because I parked facing down hill?
I have tried searching the forum plus google to see if it was a comon problem but to no prevale. I did find a seal on ebay called Window Frame Bailey Channel but not sure if that would fix the issue.
I did notice that the seal around the window seems like its a carpet kinda material and was thinking maybe its not creating a good enough seal to stop the water making its way around the glass and into the inside?
When comparing the window to the drivers side i noticed that water was sitting in the window frame at a hieght above the seal but wasnt leaking inside. Allso i noticed that the gap between the seal and the window latch was a little bigger on the passenger side(see pics below)
Any help is appreciated.
Inside of passenger sliding window.
Attachment 81564
Outside of passenger side window
Attachment 81565
Outside of drivers side sliding window.
Attachment 81566
Pics of inside the tracks of both sides for comparison.
Passenger side
Attachment 81568Attachment 81567
Drivers side.
Attachment 81569Attachment 81570
