Did you increase the slab thickness under the hoist? It is one piece of equipment Mrs mudsane has given me the go ahead for.
No I am maxed out with this hoist and have built the shed around it. I have 100mm to play with. I went and saw the hoist today and Joel said at 5'10" I will stand up under the GQ no probs.
Yeah these are bloody nice kit mate. Joel is moving 2 a day! He has about 30 in stock and has 5 going out on Monday. The 5T would be nice but the 4.5T is plenty for me. No hesitation to recommend his kit mate. I'm.impressed with how it looked. I will post some pics I took today.
Yes I added 1m x 1m pad at 200mm thick for the base of each staunchon. Should be heaps.
I went out to Joel's today and had a good look at these hoists. I have to say they are bloody good kit. It weighs 750kg and each staunchon is 300kgs. Good kit.
Joel's Garage Gear. Check them out on Facebook or their website.
http://www.nissanpatrol.com.au/forum...019/11/183.jpg
http://www.nissanpatrol.com.au/forum...019/11/184.jpg
http://www.nissanpatrol.com.au/forum...019/11/185.jpg
http://www.nissanpatrol.com.au/forum...019/11/186.jpg
http://www.nissanpatrol.com.au/forum...019/11/187.jpg
Can't wait.
Been told today though I have to wait 4 weeks to bolt the hoist to new concrete so 2nd January is Bolt Down Day.
"Been told today though I have to wait 4 weeks to bolt the hoist to new concrete so 2nd January is Bolt Down Day"
Darren, not exactly true. What concrete strength has been specified by the engineer? For example, the concrete reaches around 70% strength in 7 days then 28 daysfor 100% to allow for the moisture to dissipate. If you are keen for a quicker stand up, simply increase the strength of the concrete and ask the engineer to validate the strength cure curve. What we typically do when up against a schedule, say we need 20mpa concrete we specify 32 or 40 and it reaches the 20mpa level in the first week, so good to go. I also would recommend you use a chemset anchor system as opposed to loxins/dyna bolt or other mechanical anchor, unless yo are precasting the anchor bolts into the slab - which isnt a big deal, just needs a tempate in advance to ensure the distances are correct. The chemset system is miles in front strength wise and will never come loose. Only thing to check with the chemset system is around any residual moisture still in the slab during the process of curing to the ultimate strength.
We’ve got some Hilti sausages left over from a recent tower project if you need Daz, should still be in date by then[emoji106][emoji106]
A new upper paddock gate “absolutely” must be installed ASAP!
Mrs MB solution, circa $9k theory :-) :
http://www.nissanpatrol.com.au/forum...019/11/191.jpg
MB solution, actual $90 bucks reality :-) :
http://www.nissanpatrol.com.au/forum...019/11/192.jpg
Send in the four legged lazy whipper-snippers ASAP I says :-)
Bugger me, 240-12V pre-existing past efforts works again :-)
http://www.nissanpatrol.com.au/forum...019/11/194.jpg
New Deal: I’ll be scrubbing Dunny’s for One whole year if these little beasts can Limbo dance Trinidad style under our new gate :-)
Happy to have met a sound minded Bicyclist on our dirt road peddling solo on his way to the top!
Burning legs uphill and actually had some off-road traction on his tyre/bike choice!
100% convinced now there is a different pack breed that need to sniff lycra and follow their foolish logging truck dodging highway vegetable leaders :-)
All yours mate, not too many specys name Ramjet these days :-)
