Do catch cans "brands" matter should I fit one? GR/GU 2002 Y61 3.0 Di
Hi,
Just got a 2002 GR Y61 3.0 with 260,000 km on it. Going through bits and pieces so far so good (changed glow plugs, swapped fuel filter lift pump for a genuine as last owner had fitted an aftermarket one that hardly works, fuel filter, water sensor, ordered a new intercooler as original's leaking, got an oil filter and good brand 10w40 oil for a full oil change this weekend...).
Now, I've learnt it's good to fit a catch can on the ZD30. Did some search and found a famous car and trucks manufacturer has their own catch can fitted to some engines. And...it's really cheap to buy! So, question is does the catch can brand really matter? Actually the one I'm after looks solid and has a filter in it and looks actually good. What are your thoughts? I'm just thinking, if it's factory fitted in some big diesel engines, then it should be "good" for the ZD30(?).
Have you say...
