Hi all,
Does any one know if y61 Series 3 flares, front lights, and grill will work on a series 2? I tried searching but only engine conversions are coming up.
Hi all,
Flares are all the same for series 1,2 and 3. Headlights change from series two so you need to change the indicators aswell to suit.
Ok so the series 3 flares ( Square style) will work on a series 2 then. Just want to be clear.
So the series 3 one piece light and indicator and grill should bolt stright up with no modification ?
No thats series 4. Series 1, 2 and 3 are the same look. Series 4 onwards has the square flares. If you want to change to this, the guards are different and you need to change the radiator support panel and grille also to fit series 4 headlights. Can be done, but is a lot of work.
Ok thanks. Loving this site. Lots of help.
