Hi all. I have a 02 GU and on my way home from work everything in my dash stopped working fuel gauges, speedo, taco, temp gauge and all lights? Any one had this issue or know what the problem is, input would be muchly be appreciated.
Yep, in my 4.2 GU IV. It was a fuse that controlled the dash, the reverse lights and effected the charging of the battery. Can't remember the 10amp fuse number, but check the fuses in the panel above your right knee. The fuse was blowing because of a short at the reversing light. Replaced fuse, all OK, reversed, fuse blew, auto elec found the source of the short for me
Ok found blown fuse, replaced blown fuse. As soon as I turn the key once fuse blows again
Check your trailer socket wiring.
