If your throwing the sub filler in the same hatch as the main grab the steel tube setup off a gu.
Yep, Patrolapart said they are a bit of a nightmare and can pretty much wipe off half a Saturday.
Has anyone ever had a issue with forgetting to turn the aux pump off and running it dry?
Yes I did it a few times at the start forgetting to turn it off, the pumps don't like running dry either, overheats, etc.
One best way is to fill the aux tank up, do a full pump to a main tank in your carport and time it and use your timer whilst touring to remind you.
About to wire mine back all up. . . Hope it all works [emoji53]
So anyone want a gq tank?
Mudrunner gave me one a while back that needed repair.
Repair has been done but it needs the strap mount to swing arm mount.
Basic bit of flat bar with a hole.
Sender is shot but there.
Clean inside.
Only down fall is its in mt gambier lol..
