Mike02Ti
Just because your point is rated to 5000kg doesnt mean you can swing 5000kg off it.
Many other factors can come into play. Chassis strength and the actual condition (eg rust inside) of it being one.
Another is the other rigging gear your using like shackles , extension straps, the bolts holding the recovery point or anything else used in the recovery
Say for instance your 8000kg snatch strap is used off one 5000kg recovery point.
You connect to the bloke helping you out with a hitch reciever with a 4700kg shackle
Now on your recovery point you attach a 3200kg shackle. The whole system of rigging gear thst you have just attached is effectively rated at 3200kg as that is the weakest link. Hope this makes sense.
I have even seen recovery points put on with bog standard galvanised bolts. Bloke didnt know any different. They fit and screwed in and he used them not knowing they weren't rated for bugger all. All he said was they wont rust. So something else to check as your hooking up.
If you bridle it depending on the angle of the pull, one side of the chassis will load up more than the other if its anything other than a dead straight line pull.
Side loading may also play a factor depnding on the gear used.
Once extra angles come into play and side loading etc all these factors will reduce the SWL of the recovery. But yes a bridle should be used wherever possible on both cars , not just the one being recovered.
Its something to be very mindful of when doing these recoverys as the forces can be tremendous.
