Don't worry mate, I wanna do a little get-together one day..
Calzone pizza and we always finish up with a Nutella and marshmello pizza.http://www.nissanpatrol.com.au/forum...2022/06/66.jpghttp://www.nissanpatrol.com.au/forum...2022/06/67.jpg
EOFY buy _ Just put deposit down for a new shed - open floor plan (Tradies Workshed) 9x16x5m 3 roller doors + pers access door across 16m front (4x4m bays)and advertised as room for a hoist..hmmm
Suggested hoist to good wife and seem there could be a possibility:Yahoo!:. @MudRunnerTD what did u buy and tell me more (2 or 4 post and would prefer adjustable lift jack pads in lieu of ramps).
Awesome mate.
I have a Joel's Garage Gear 4.5T clear floor 2 Post Hoist. I like the clear floor as I'm not tripping over the base. You need 3.6m clearance to top of post.
They also do 4 posters and 5T Clear Floors. Jump on his website. Everything you need to know is there. Note you nèd to build in a 200mm x 4.5m x 2m pad into the concrete to copw with your hoist.
Note you will need to a few accessories when you go to a Hoist. Happy to share what i have added when you are ready to go mate. Allow mate an extra $600 to $1000 for extras cause you really will need at least some of it.
Thanks Darren for info. Checked out the Joel's site. The 4.5T / 2 post clear floor is what I am looking at (attached Proworkshop Gear _ Jackaroo 4.5T / 2 post and looks similar) but your hoist has the manual locks on both sides. You have used the Joel's 4.5T / 2 post that must suit your need and that gives me a bit more confidence of suitability.
INFO:
https://proworkshopgear.com.au/produ...-m/#closemodal
The shed will be a few months away for delivery and size is 9x16m with 5m ht clearance and open floor plan. Will ensure the 200mm slab thickness for 2 post install.
The 240V / 20 amp requirement for Joel's is more than proworksgear 4.5T that require 240V / 15A _ I generate my own power 5kW continuous but can run the generator to help if needed but I can supply surge pwr so should manage the Joel's hoist. The 20A is most likely to start motor (P1).
The Joels has a bit more lift ht.
Any issue with patrol clearance to the hoist top spt frame?
Would be interested in the accessories that you bought and any further comment . Thanks mate
Finally I worked out the correct Pot to pour in Power Steering fluid [emoji23][emoji120][emoji106][emoji106]
Borrowed a Navara D40 thingy today and it stopped assisting steering in the middle of the Tullamarine airport carpark dizzy skyward ramps….levels 1,2,3 before my arms gave up [emoji23]
Early Monday finishes are best Mondays ...
Few frothies by the backyard wood feet heaters can't go wrong.
http://www.nissanpatrol.com.au/forum...2022/07/32.jpg
If this isn't the funniest thing I've seen in a week....
https://www.youtube.com/watch?v=wCp4J3mvhmE
Yep you guessed it....bored and half cut in my motel room home away from home gone down that rabbit hole again!
