2000patrol zd30 loss of power after 6 sec
Hi everyone,
My names gav,got a problem with zd30.direct injected. After 6sec of excelleration I loose all boost. I then take foot off and back on then boost returns. I have replaced every thing under bonnet. No engine light appears therefore no codes.please help .cheers.
Quote:
Jacko71
Hi everyone,
Hey gav hope your well I can tell you exactly what this is mate. This will be your car going into limp mode like the evil twin said. Do you have a boost controller on the car. There is a boost sensor on the inter cooler this reads the boost within the intercooler and has a cutout boost of 16psi which sends the car into limp mode. Well more of a limiter the revs sit about 2000 rpm and no matter how much gas you give it no increase.
Unless you have your boost set to a really high setting that’s the only thing I know to set the sensor off.
My patrol did it when I got a Dawes kit for it but after fiddling around with the boost setting it was perfect never went off again
Jack
