Twicehttp://www.nissanpatrol.com.au/forum...2021/12/96.jpg
Changed the oil even though it had done around 2000k since last service.
Letting the oil drain overnight made removing the two oil filters a lot less messy. If you’ve change TD oil filters before you know what I mean.
http://www.nissanpatrol.com.au/forum...021/12/104.jpg
Ah, but its only messy if you dont make a little drip tray for the filters with a drain pipe that goes behind the starter :)
Attachment 84889
I never ended up getting this tray from that chicken bloke on the other forum. But was meaning to... Also what a nightmare to install unless motor is on the bench.
What black magic is this?! Bang Head:smileyvault-cute-bi
No matter how long I leave it draining out it's always the same. If I look at the internals of the filter, there will always be a pool of oil within it, that cant drain out unless you tilt the car 90 degrees onto the passenger side. And always wooshes out right at that final thread turn of the filter....
Few things that didn't all happen in a day.
Been a year and a half since I flushed some seriously chunky rust out of the rad and the coolant was brown again so once again I left it a bit late.
Cut a large Titan fridge slide to size and mounted it on some gate hinges for some tilt.
Attachment 84898Attachment 84899Attachment 84900
Replaced some gas struts to stop the sides on the camper falling on my head and made them a little longer on the kitchen side to give my head a little more clearance when up which is a stop gap to getting some new springs in the rear of the old coil cab.
Took the old girl down Warrnambool and set up camp on a dairy farm where it was ~10c cooler than back home in northern vic.
Attachment 84901
Water was borderline boiling point on the way home with the ambient nearing only 40c I had to turn the AC off a few times to keep it under the first max temp line while going up some hills.
The EGT going from the usual 250-300 to 300-375 post turbo was still ok.
It was interesting turning the AC on while rolling down a hill in second you could actually feel the ute lurch as it cut in.
Also been in contact with WolfBox about some intermittent gremlins with my rear view camera and they have been excellent to deal with sending me out a replacement right away and then asking if I would like to send them some video of the old units touch screen problems.
They seem keen to improve there product and are looking into what went wrong with mine.
