optic
I took note of the work done to ad another plate, that got me thinking of doing the same thing, the same way.
I have a couple of questions.
Who can i get them from off here and how much, you can PM me if you wish.
Second question is this.
Has any one adapted the plates together, by that i mean a cross member from 1 plate to the other using the existing unused holes in the plates ?
I intend to machine a bar of 50 mm dia with tapped holes in the ends to slip in between the plates to remove any independent side action when both are used together as one ?
Any feed back on the idea will help.
