Original came with 265 I'm running 275s currently with no lift
you're getting good miles from your Patrol thats for sure
Yeah its going well I had to replace the injectors due to 2 leaky ones but it's going well had my first sliced tire last month was a fresh grated road will definitely lower pressures now was a costly exercise
Even if you only lower to 30 psi it helps,
at least you can drive on hwy if you forget your compressor
Thanks for the tip I'll remember that!
