Plasnart
John I just went out and replicated your problem, child lock activated so it wasn't openable from inside. Get yourself some stiff wire like coathanger wire. Put a 90 degree end on it about 5mm long. Slip it behind the door seal from inside, hook the seal and pull it inwards until you can grab it with your fingers. Pull the seal inwards and you'll just see the child lock. With a bit of dicking around I got the 90 degree bend at the head of the wire behind the switch and pushed it to the unlock position. Took me 5 minutes.
