GQ Patrol - No Keys
Hi Team,
I just purchased a "Project" 97 Patrol RX Turbo Diesel..its in need of a fair bit of work. I had it transported to my garage , the previous owners have lost keys...so the first job is...either change ignition barrel/key or is it possible to get key cut to suit ?...cheers in advance for any info.
either way the barrel has to come off, so find a cheap second one or take barrel to key cut place to get a replacement key for that barrel and hope they don't change the key format /foot print, that way you can you it for other doors on the patrol
most qualified locksmith can make a key to fit the ignition unless its too worn. If it was one key to suit all locks then it will still fit all locks.
Pete
most qualified locksmiths can make a key to fit the ignition unless its too worn. If it was one key to suit all locks then it will still fit all locks.
Pete
Get locksmith to re-key the locks so the old "Lost" keys can't be used.
Ask Nissan for the lock codes then go to a real locksmith, not a Mr.Minute, and they can cut new keys by the code. I did this with my own Patrol.
