Can any one tell me the size of the pin on the kaymar swing arm ?
From memory there are two styles. The original used a parallel bar circa 25mm, at least thats what was on my troopy, then they changed the design to a trailer stub axle design as it was a better system and didn't have seize up issues. What style do you have? Or are you looking to fab one yourself/
I have a bar on my Gq with a stub axle on it and some friends have there old swing always arms of there Gu I think it was a Gu just seeing if it would fit on mine
The Kaymar bar on my Series 1 GU has Holden stub axles (LM bearings), but i believe later bars have Ford stub axles (SL bearings). Not sure when the change was made....
