Had a look around bell housing, no oil evident (all glued up/silicon), even fork boot. Would not take much oil to weep if was cause. Will drive same hill it this arvo and see how goes.
Retraced my drive of last night and am 90% certain clutch need replacing. First climb 4th gear / 75% eng load @ 450N-m started slipping real bad, revs just ran away. Turned around came home the easy route, but once again 5th gear 450N-m @2250rpm she slipped away, stopped and had strong smell of cooking clutch plate lining mat'l.
My pedal is very high and think the clamping force would be very low.
Was thinking of doing a run down sth for install as was thinking of putting in reduction gears at same time, but doubt I would get over the divide. Make some phone calls tomorrow to make final decision on clutch conversion kit(HD withg SMF). So many suppliers do not state performance data against there products on line.
I use and always have the Clutch Industries 4 Terrain clutch. Never had and issues with it, my motor is now circa 650nm and the clutch is holding it easily.
Without sounding over opinionated and narrow minded, any chance i can convince you to go auto?
I couldnt imagine anything worse than buying a clutch again amd eventually flogging it out due to the high hp and weight of our vehicles.
You can purchase an re4 auto and a manualised valve body for around the same price as a decent clutch and you'll never have to worry about frying them again.
Yeah they suck a bit of fun out of wheeling but your low crawl control is second to none, on road is better, less time loss between gears etc...
A manualised auto still requires you to manually change gears if you like the manual feel of driving too.
I have a fully built fully manualised re4 auto thats rated to 1000hp and theres currently one in sydney running 9.90s down the quarter taking constant abuse...
Speaking of which, i am currentpy making close to 450rwhp in my patrol for close to 2 years and i can tell you now there is no way any viper clutch or other ckutch will cope with the power amd weight and stuff i have done in my patrol even on the street.
We are currently waiting for a new cooler and echaust to be made to retune it for a rear wheel figure of over 500rwkw (700rwhp)
Just my two bob... its never too late ;)
@Baby Daddy your numbers are certainly from a different league to my CRD. I run a VNT Procharge stage 3 h/f turbo @ 27 psi that takes a bit to get the turbine to spin up below 1500 rpm and an auto box running higher/quicker change would most likely help out but guess I am a bit old school.
The 4 Terrain is there heavy duty range. Like the Tuff Clutch range of Safari.
http://clutchindustries.com.au/range...ainclutch.html
No part number sorry, theres only one clutch that will suit yours. And I was running a solid flywheel...
