Further to my steering wheel shake ......
Just had a new set of Superior Engineering 2" caster correction bushes fitted hoping that may fix or reduce the wheel shake. Well it did something. Now, at 110klph and over, not a hint of a shake or wobble. Vastly better than before.
But now, at exactly 80klph it's nearly a "tank slapper", very dangerous, and much worse than before. One of the front wheels previously required heaps of lead to balance. I'm hoping it is a wheel problem because I may sell the steels & muds and put some AT's on the mags if I have to.
Today ...
I've just had a wheel alignment, balance & rotation which has discovered an issue. The two front tyres are badly "out of round", they have many high spots which may be causing the problem, although there is no obvious unusual tyre wear. The two rear tyres are perfect. We've swapped wheels front to back and the 80klph "tank slapper" is gone, hopefully permanently. What a difference, makes driving much more pleasant. The shop seems to think that two of these tyres may be faulty and has reported it back to their supplier, as this is the shop I purchased them from. Them seem to remember a similar circumstance around to time I bought mine from them. Who knows, something or nothing may come from this. I've "over inflated" the suspect tyres to hopefully run the centers down a bit. If that does nothing I may replace them or swap the lot to AT's.
Anyway ...... at the moment I'm very happy with the outcome. I hope I stay that way.
