PeeBee
Be careful with anything mounted to the cargo barrier. I was hit with a defect notice from the engineer when it went for engineering re motor/gvm, as the perception is that a passenger could hit their head on anything protruding from the cargo barrier. I had to remove it all for the certificate, then half went back, the other half mounted on the rear side of the cargo barrier, Its a fair point, but a waste of what seems a good mounting area. I have a large SS water tank behind the rear seats, hence cannot mount the gear down low like 3D suggests. If you that, then you won't have a problem, unless some 'smartie' comes along and takes exception o the mass on the cargo barrier and loading on the mesh during a sudden stop - if mounted behind the seats though you would think it would be ok.
