Morning,
I need some advice as to what bolts to block off the old coolant lines in the block of my zd30 2001,
Morning,
I think the hose is 5/16th or 8mm give one size
a try when its cooled down completely
Thanks for the reply, but not quite what I was after..
I want to seal off the block as I am no longer needing the coolant lines to the turbo. Guess I'm after the specs of the banjo bolts that would normally hold the lines there
I think your only option is to remove the banjo bolts and take them to a bolt shop for measurement.
