G'day mate - welcome aboard. Great people, information and laughs on the forum mate, so don't be shy and join in whenever you like to make the most of it. Enjoy!!
Welcome aboard Joe
these guys have a heap of helpfull stuff on almost anything you want to know
i've got an older rig and the forum members have helped me out heaps on various issues
lookin forward to seeing photo's of your rig mate
Hi Folks
Now have picked up the camper and will fit the Solar power soon.
The next big hurdle is to find the time to use it!
Working T,W,T with a 4 day weekend so it should work out fine
Comming home from Coffs Harbour the fuel consumption was around 13l/100Km at mainly 95KPH
So looks good for a fuel range of >800km on standard tanks
Will look at the fuel pick up on the Sub tanks as it may be lesaving some fuel behind
I have a Filter seperator for Sub tank to main and Main tank to engine so can run the Sub tank nearly dry
without any bworries
G'day mate - welcome aboard join in and have fun mate plenty to do see and if u have any problems just ask and im sure u will get an answer ENJOY and WELCOME
Very Nice Mate
Tim
Welcome mate, have a poke around & join in when your ready.
Hi Joe,
Is this the car your looking to upgrade to 3.9t GVM?
So this is a little harder to just buy and sell for sure. If you want to GVM up this you will have to get it Engineered again, Maybe a Swerve test too. Could be very expensive.
Hi Mudrunner
Yes this is the beast and it drives sweet like a limo with 7.2m total length
and great in the desert just need to make it legal
The local engineer is happy to sign off on 3.9T just need the leaf spring converesion
Joe
Then it would be fairly easy to do to be honest. I'd be looking for a full rear leaf diff housing and see if you can cut the mounts off the donor chassis. Most wrecking yards should have what you need.
Good luck with it mate.
Welcome aboard Joe, have you considered these yet mate:
http://www.firestoneip.com/
Patrol Apart recently installed for me in my GU Laingley extra cab. My trays still off atm so can't give it a full on and offroad test. Full coil replacement just bolts straight in! Of course, please do add tower bracing, but I reckon they could spec up bellows to suit ten fold what you're after. I'll go take a pic in 5 for you to see.
http://www.nissanpatrol.com.au/forum...2016/06/50.jpg
http://www.nissanpatrol.com.au/forum...2016/06/51.jpg
http://www.nissanpatrol.com.au/forum...2016/06/52.jpg
And we went with Koni 90s over the 88s, lost some travel 15-20mm but recommended for the weight of my counterlevering tray out back !
