I’ve got a set of factory flares I want to install but don’t know what clips to use to fit them.
I see a wide range on eBay as I’m a bit scared to go to Nissan, I don’t want to mortgage the house for $5 worth of plastic clips. Any advice welcome.
You can go to Nissan and they will show you the exploded diagram for your model and sell you the right ones. They are cheap and easy. They will even print off the exploded diagram for you.
The other thing to keep in mind is the rubber seal that goes between the body and the flare. If you don't have those, you'll need to source them too.
I bought a non-genuine clip set and genuine Nissan rubber seal from patrolapart to repair my passenger door flare on the driver's side.
