Would be great to get the flywheel with the motor and the PS bracket would be a winner too. Id think you could negotiate that into the deal
Think you should just put in a TB4.2, I know of a good motor going for cheap in Sydney, ya just need 2 get the spark plug out :animierte-smil
Are we going to be able to use my clutch? Mine is fairly new and I would like to use it in the new engine but have read some conflicting info on the internet.
Yep the spline is same so will be fine.
Yeah ok mine fitted perfect with no modifications.
The sandwich plate on the turbo motor is different, it has a bigger hole for the bigger crank.
I can either buy a new one or grind out the hole to the larger size.
Does anybody know the measurement for the hole to fit the bigger crank?
