Its just a rubber hose adaptor, so going: tb42 chassis hardline > tb42 fuel hose > adaptor > td42 fuel hose > td42 fuel filter hardlines. Now found out I need one from the injector pump return also :| Back to Enzed I go.
Well its finally done and I am out on the road, quite an experience. I am glad I did it but won't be rushing to do it again it took me a long time. I am no expert when it comes to working on cars though and this is easily the biggest project I have ever undertaken.
I had some minor issues getting it all buttoned up, primarily finding a suitable wire to use for my fuel cut solenoid on the injector pump. I probed around with my multi-meter to find a wire that was 12V when in ON and START ending up finding one that was right near
the injector pump as part of the large amount of wires used for the efi system. What I failed to check is that this wire had enough amps to switch the solenoid (it didn't). I ended up using the wire that goes to the coil on the other side of the engine bay. Some things
left to do is. Wire up fuel, temp and tacho gauges. Tidy up existing unused wires from the efi system. Install my fancy new Stedi LED headlights. Swap over the suspension from the old rig. Then hoping to turbo it in my break at the end of the year.
Thought I would give this thread of a general update of what I'm doing with the car. Good for me to look back on in the future. The patrol had been leaking oil more and more severely and I diagnosed it as a rear main seal, when I installed the rear main during the swap I noticed that I had marked the rubber lightly but I thought it would be okay as it was on the non oil side. Anyway given the current state of events and not having a job I decided to do it this weekend. Friday ripped most of the accessories out, Saturday got the engine out and the seal swapped over, with the ingenuity of a mate to make a tool to press the seal in straight this time. Sunday morning got the engine back in and lined up on the mounts, then had the arvo off. Finally on Monday got all the bit and bobs back on and she started up first go. Some notes from the experience:
- Need new engine mount bolts, the threads aren't looking 100%.
- Getting the engine lined up to the bellhousing and engine mounts was more painful than I remembered.
- Need a new coolant and heater hose kit, mine are a big haggard.
It's kinda a shame I went to all this trouble just to do the rear main when I was planning on bolting a turbo on soon and it would have been nice to do that while the engine was out, but corona times call for corona measures.
Also can a mod please change the name of this thread to Auspecial's GQ
Hi mate, just pm @MudRunnerTD or @Woof
