What 2 inch kit woyld you recommend?
If find most recommend Old Man Emu (OME). But not sure if they do a leaf setup.
Most leaf guys go shackles. Not legal I all states to check that out.
But if your happy with the ride of the MQ maybe a spring height reset is the best option for you.
Our local spring joint resets springs for between $50-100 each depending on how much work they need.
Best advice I can give is read up in it all mate.. Check out other Patrol forums to get a good range of info.
But don't rush it. Enjoy it.
Have you thought about doing a Rhino 4 link conversion?
Spicer Springs in Bayswater- Vic I used many years ago to reset my old GU DX Leafy arse end springs.
Was recommended as the best mob around then and outcome was true to the word.
They’ve been doing exactly what seems you need for a long time and earnt their stripes then for sure, hope they’re still around[emoji106]
EDIT: Found them on McGoogle now moved to Knoxfield and still going strong 80 years now it says [emoji106][emoji106]
https://www.spicersprings.com.au/
If you put 2" over stock extended shackles in the rear you only lift the back one inch.
you need to do front and rear to gain a full 2"s or you could if possible do a spring over coversion,
but probable illeagal these days check RTA in your state
