Bump........
Bump........
Awesome well put together
Yep I'll be needing this one soon
@AB Check out the photobucket pics above mate? Now have a water mark but are showing up? Is this across the forum?
Hi Darren, commented on photo bucket watermark earlier today incorrectly, note that only post 17 pic does not have the water marks.
Looking at replacing GU inner axle seal and came across this thread. Tony has done a good job and yes the effort that he went to is terrific.
Some yrs back I replaced wheel bearings, hub dust seal, removed & greased CV and now the inner axle seal is weeping. My knuckle assy is in good nick, so will just repack bearing, CV, install new hub dust seal and inner axle seal.
To remove inner axle seal do I use a finger type inertia puller or what did you do (have not yet pulled down)?
Recall that you did a rebuild thread for front axle/knuckle flange assy, could you attach link. Thanks mate
