I'll grab a quick pic tomorrow arvo for you mate.
The bolts should all be very obvious though.
hi winnie
how long did this take
anything youd recommend when doing this again
i may be doing this soon
my engine has me dumbfounded as it has 55mm cranknut,oil drain in sump water lines into turbo from thermo housing but mine has a low engine number td42091600 1999 model
thanks benny
i thought with the factory 1" oil drain, and bigger crank would exclude this being na
finally found that a 55mm crank and block drain will generally mean its a t engine
