I am wiring in my in cab winch switch.
It is a 6 pin SCA momentary switch.
Does anyone have a wiring diagram they can share?
I have 4 wires and was wondering what pins I should be using.
Hey mate, if it's a Carling type, this might help hopefully. . . Need to re wire my one too, isn't working atm. . .http://www.nissanpatrol.com.au/forum...2017/09/65.jpg
Thanks for that but I have a 6 pin switch.
Turned out to be pretty simple.
3 wires only as the unit is grounded at the control box on the winch.
3 pins on the left TOP - IN, MIDDLE - POWER, BOTTOM - OUT
The pins on the other side weren't used.
Make sure you have a master switch inside as well. Don't want to accidentally wind the winch in while your driving.
Could ruin your day lol
Yeti I have installed an isolator switch as well :)
. I had heard that before and made sure it was part of the set up.
I have posted a pic of the install in another thread.
