Hi everyone!
So, what do you think can I fit 31” tires, without any lift works on my Y60 94?
I think to use R15 discs from Pajero.
Hi everyone!
Yep the 31s will fit without a drama mate! They are standard issue on the Patrol mate.
31" tyres are not a problem at all mate. If you're wanting to use the rims off a Pajero, I doubt if they will seat properly on the patrol hubs. The Pajero stud pattern is 6x 139.7mm with a 108mm centre bore and the Patrol stud pattern is 6x 139.7mm with a 110mm centre bore.
Someone who has a better idea might be able to help you further.
i was running 33in on mine without a lift for years no problem just a little bit of rubbing every now and then
