Yeah I've seen a few faceache post of CC intake manifolds opening up along the welds (dodgy looking beads). Have any coolers actually failed though?
Do you get a lot of noise through yours when you accelerating hard @Stropp? Mine is quite loud. I was annoyed with it at first but now are used to it. I did read somewhere a fella moving the mounting tabs on the brackets and using rubber isolators between the cooler and bracket. Apparently made a difference.
Yeah as I mentioned coolers seem to be lasting but the couple of manifolds I have seen pics off opened like a can of baked beans along the seam. Could have been an isolated (apprentice welder) case, however disappointing to see poor quality control if that is the case.
I get a lot of air rushing noise through mine especially when the boost gets up and going.
But I've driven 2 others and it's the same. Including Mudskis .
But it cools, does it's job.
The Cross Country web site is bloody average! there seems to be no Shopping cart function! Who Does That! also the kits are not listed with a "Whats in the box" type list. can you guys confirm that the scoop is colour matched and did you supply the colour code at the time you ordered? Did the kit come with a template for the Bonnet cut?
Can anyone tell me the difference between the GQ cooler and the Ultimate Cooler for the GU? Other than $400? Struggling?
Maybe these variations in noise are more to do with the other things done to the rig, as stropp mentioned "no noise" but I can see he has a 4inch snorkel, I'm guessing then the air box and Inlet to turbo is upgraded. I wonder if this would make the difference. Also with the top mound there is very little pipe between the cooler and inlet, add to that the fan which I believe runs off of the radiator temp and it being sooo close to the driver could add to the noise when running.
Also as someone who lives in adelaide I'd like to think a lot of the issues people are having are a result of the demand on cross country, I drive past quite regularly and I don't reckon I've ever seen the car park less than 110% full, I'm sure there's cars parked across the road to, hopefully it's something they can address but when they cover so much like car servicing and pre trip checks I can see why they're so swamped. To popular to quick me thinks.
