Cuppa
I'm interested in what reducers you will be using.
I've just had a play with some reducers / hoses I've come up with in our diesel hydraulic mechanics work shop.
One issue I'm slightly concerned about is the internal hose joiners greatly reduce the internal diameter of the hose . So when a joiner is inserted inside a 16mm hose, the hose gains a 11-12mm internal restriction. If that makes sense.
Now I don't know what pressure this works under or whether or not this will be of any hindrance.
I've got the reducing kit pictured below at home but the joiners internal passage is 10mm at most.
