Hi lads and ladetts, just wondering does the gq Work shop manual on here give a detailed description/image of where they all go as I have hose's disconnected everywhere(just purchased the vehicle) can anyone draw up a diagram?
Cheers Justin.
Cheers Justin.
Hi Justin
Here's a pic of the front end if the engine, I will take a picture of the aft end tonight.
Hope it helps.
http://img.photobucket.com/albums/v9...7DE0C10B86.jpg
i dont think the manual on here has any info on the efi motor, but dont quote me on that
Thanks parksy it'll all help. Where'd you get that blue vacuum hose from? Looks awesome.
No dramas. Bought the hose from eBay. Cheap and a good way to eliminate any possible vacuum leaks.
What is it, Silicone tubing? What size is it, 1/8"?
Yep silicon tubing. Can't remember the size I ordered but 1/8 sounds right.
Lucky it's blue, makes it heaps easier to follow.
http://img.photobucket.com/albums/v9...AE890CF942.jpg
http://img.photobucket.com/albums/v9...AE8E7EDE9C.jpg
http://img.photobucket.com/albums/v9...AE92CCDEA1.jpg
http://img.photobucket.com/albums/v9...AE991D3EBD.jpg
http://img.photobucket.com/albums/v9...AEA18CAC4E.jpg
Should mention, the line running from the purge canister to the inlet manifold is larger than 1/8. Maybe 5/16. cant remember, but either way, it's larger than the other vacuum lines.
Funny this makes me want to check some stuff on mine?? so blue........hmmm blue!!!
Thank you so much! :) I tried taking photos of mine but its no comparison to the blue. Makes it so easy to see! Think you might be starting a new trend with that hose hahah.
Cheers Justin.
