http://www.nissanpatrol.com.au/forum...uto-hubs/page2
From my readings over the years the Auto locking hubs are stronger than any aftermarket manual hub, If out bush doing tracks then lock them in, if out and about having a quick play leave them in auto just remember to reverse up a few meters after changing back into 2wd
Never had to do roll back disengagement since good old FJ45 days.
In GU auto mode, slap mine from 2 - 4 wd on the move heaps and never had disengagement issues. First, always at idle, before driving off (auto mode) I just engage/disengage from 2H to 4H a few times and then I have now engagement issues or clicking noises. Without doing this I have engagement issues (won't engage and click away). Have also been running LS90 in front diff for past 5yrs. Next will use 80w90 mineral.
Sorry John mate, was referring to the Eaton Locker from the video and how its mechanism is designed.
After engaging it takes a 1/4 turn to lock forward so if urgently reversing up it becomes a full 1/2 rotation to relock backwards again apparently.
Definitely worth a view mate!
Unfortunately now for us just learnt, even though we were very much looking towards an easier installation system for the old family truckster it won’t suit our future needs either like the narrator shows.
There is plenty a rocky shale little track around our neck of the woods too that just wouldn’t forgive a start/stop/reverse/start again situation.
Our little 33” KM3’s I believe would equate to over a 1.3m half rotation distance rollback (or wheelspin) before engaging again and then the same again forwards back up a hill?
Did check it out, the guy certainly gives the pro locker a push and quite rightly so as the Elocker achieves positive lock (direction change) only after it overcomes the cam operation lag (bit ordinary). Hard core or not, it would feel loose "loss of direct control" for the 1.3m at least(.5x3.14x33 converted to SI units as U said).
Have to be careful with either running DC cable or hose routing (risk always exists from, being knocked and time fades away (Neil Young) once install completed.
Be interested though of difference in the Australian variant of Elocker operation to compare out of interest only. Have not the real life experience as demonstrated, but from what I have seen here recon the air control system for me.
I love my Elocker. It hasn't had a huge amount of use but on the occasions it's been needed it's done it's job. From the video I can see their might be an issue for some, but for the likes of myself it offers me the reassurance I need. When I need to use it it is invariably on uneven steep terrain where commitment is everything & where hesitation & rolling backward is to be avoided at all costs (particularly as I have the Tvan in tow). That said many of the experienced or 'hardcore' drivers here would probably manage the terrain I would use the locker for without need to switch it on. For me it's mainly about avoiding the risk of vehicle damage, by not relying so much on momentum, when alone in remote country. For those who use a locker to enable them to conquer ever harder terrain then maybe the rolling back issue is worthy of consideration.
A bit of topic but related. I do not have either low range reduction gears or diff locker fitted. Would the reduction gear for low range application be the priority install of the two options (when stop spending on other bits)?
