If that is the same material the rv is made from then yes, for sure.
I wouldn’t think they would change from something that has worked for them so well
................on the move
All the rv range is 8oz poly/cotton canvas, the swag is this ModCan material what ever that is.
I'm older than that by 10 years, 140Kg and knees are shot
If I lie on the ground I need a Fork Lift to get up
You don't need an RV3 unless you want heaps of room
I have an RV1 and it fits a large single camp stretcher with my king single swag on top of that no worries.
Plenty of room left for bags and gear.
Comfy as with large vents/windows... and 150Cm's high means full head room if I am sitting up
RV2 is OK as well but is longer when packed (same length as the 3/4/5) and I wanted one that would fit in my Tray.
I reckon if your chasing an RV type tent then go the RV4 as its a great size. it really is not much different to pack and will take your gear easily. Got room if you end up taking a grand kid or something and a little more flexible. Great tent. As you get older a little room around you is nice, dont rip yourself off.
I have an RV5 with Peaked front but rarely set up the front. I have the storm fly that i leave permanently connected and pack up the tent with it connected. Often i will leave the front awning just hanging or in bad weather i will peg it out 500 away at the base without poles to allow me to slip in behind it and get in the tent. I can take my boots off under there and leave them. That is probably what i would do with the RS1 too which then basically makes it look like a conventional Peaked tent where you crawl in one side.
One night on the way to the Simpson we were camped at the Caravan park at Orooroo in SA and damn did it rain! Hard!!. i had mine set up as above. it was hot and wet as a shag. I had good ventilation and the storm fly kept the main tent basically dry. @AB and @Winnie got flooded out and ended up in the Laundry for the night and i was bone dry. funny night.
What confuses me is that this cut down tent is about as close to a swag as this Darche unit. The only difference for me is perhaps the extra 120 seconds to get it up and maybe the breathability, but is it worth the cost difference - both are essentially 2 man tents.
https://www.ebay.com.au/itm/Darche-D...QAAOSwA3dYhBaG
