Way to small
Oh sounds like the DTS is pretty good. Do you know what turbo its running? And i thought the T28 might have been a bit too small as well and I didn't like how it was welded at all!
I have also seen Safari Kits as well are they just cheap crappy kits or not too bad?
safari kits are also ok and will do what you want.
The old ones ran a bigger rear housing than the newer ones.
I ran both, both were good, the .63 rear housing was out of puff by 3500, and wouldnt make more than 14psi. But it did it pretty early.
the .82 I had first had a cracked wastegate seat, so was tough to compare
I know have a TD05 18g, and it too is very goood, but with the right pump...
