Disconnecting the Y62 Shunt
So here is the first Mod you should do to your Y62 if you intend to install a second battery. Lithium or Gel, makes no difference, this needs to be sorted.
The Negative Shunt is factory fitted as part of the smart Alternator to turn down the charging voltage from 14v after start up to a tickle charge of as low as 12.2V. A Lithium or Gel Battery does not like this at all. Removing the shunt let's the Alternator produce 14V all day.
This is as easy as it gets and will take you about 1 minute...
All you need is your glasses on and a small flat head screw driver and a 10mm socket or spanner.
So the Shunt is attached to the side of the negative battery terminal. Right here.
http://www.nissanpatrol.com.au/forum...2021/09/69.jpg
First disconnect the negative terminal with the 10mm socket and put something over the battery post to stop it arcing while you work.
Lift the terminal off and you can see the shunt.
http://www.nissanpatrol.com.au/forum...2021/09/70.jpg
Use the screw driver to leaver under the crazy little clip on the side. This was a bit of a bustard but it got done.
http://www.nissanpatrol.com.au/forum...2021/09/71.jpg
Pull that sucker off.
http://www.nissanpatrol.com.au/forum...2021/09/72.jpg
Then shove that sucker down the side of the battery and forget it was ever there. Never to be spoken of again.
http://www.nissanpatrol.com.au/forum...2021/09/73.jpg
Happy Days!!
