Its only 25mm when folded,,,,, at a guess Id say it fits,,
no-one has drawers that close to the rear doors,,,,,,do they
I measured mine and it's 35mm clearance. If your drawers are located on the floor as close as possible to the rear doors, I think about 35mm is the norm in GU's. One thing you need to check is the thickness of any draw handles you may have. That could be an issue for some if you have a draw on the RHS.
Ok bazzaboy here we go.
1. The lights are LEDs
2. The light dose have a switch on the right hand inside edge.
Attachment 68476
3. I needed to take 20mm off of the bottom edge plus the far left end of the bottom from the left edge 75mm in, a further 15mm. So 75mm from the left in I took off 35mm and the rest of the bottom only 20mm to fit the mouldings in my car. Now I don't know but I would say there may well be slight differences in some models so you would have to measure and double check yours. Hope I've explained that well enough mate.
