Hi! i need to know what kind of conversion kits that i need for the cummins 6bt 5.9 1999 mod to fit the original gearbox and clutch. it is the manual 5 speed gearbox. thanks for help!
Welcome to the forum. Please head over to the introductions thread. Marks Adaptors should have what you need. https://www.marks4wd.com/
im sorting out a 6bt manual in a 1998 GU at the moment , forget the original clutch , will need a ceramic button set up if you are going to fuel up the 6bt , what hp 6bt are you planning to run
