ps, hoping that bigguwesty Kallen will chime in since he is nearby for a guide as to which places to help with exhaust/pyro bung etc
Lana if your intercooler is the original. Have a real close look at it for leaks. If you have any boost leaks at all, no matter how small, there is no chance of setting up the valves. Do you need a weld in bung for the exhaust pyro? I have 1/8 npt weld in bungs. If you want one, let me know via eBay messaging before 12pm Friday and I'll chuck one in.
Thanks for your order too. Its greatly appreciated.
that's a nice offer thank you mudski but yes I have one. I am also making enquiries about a intercooler upgrade even tho' there doesn't seem to be any leaks at this point.
the kit arrived today mudski super quick thanks, have the pyro in now, taking it for a spin this afternoon to see what its doing before I start on the install of the kit. thanks again.
mudski sending you a pm, hope its ok.
after a hic-up with my pyro, took it for a cruise down the highway at 100km on cruise. Boost was varying all over, but mostly around 15psi, pyro was about 300.
then took it up our one and only hill, about 75m rise over a 1km distance, so reasonably steep.
on cruise at 110km, pyro hit 475, and boost was 22, but dropped back to 10 as I got almost to the top of the hill. I lost maybe 5km/hr up the hill but wanted to see how it went basically standard except for the exhaust.
next step will be the dawes and needle, and where to put the needle for ease of adjustment.
With the passing of time, good info from this forum, other place along with a better understanding of my CRD manual boost control, I am satisfied with current run result:
Just did a trip to mtns total climb 600m over 150km run (some decent long hauls) getting max boost 17/17.5 psi at 100k/h (2500 rpm) and holding that boost level as revs decreased and where the speed did occasionally increase (long haul), the max boost went to 18psi @ 2800rpm. Cruise boost @ 100k/h (slight load) of 15-16psi. EGTs, cruise say 325-400 degC and on long haul solid work 600-680 odd deg C. Lower cruise boost with OEM ecu mapping proves to be too sluggish for me. Did some low range work, the torque increase and response at low revs is impressive compared to before NADS install. Next will likely do ECU remap.
Also, I use a throttle control unit that does effectively reduce throttle lag and provides real time quicker pwr response but it is worth noting that the rate of response differential is not as noticeable now since NADS install but remains effective and do adjust it for various driving conditions.
Successful Manual Boost adjust for Stock ECU Kallen, ECPT returned my ECU yesterday as they did a postal remap of my 08 CRD stock ECU. I have set Dawes to provide a Max Boost of 21psi with needle closed (No limp to date hauling). ECPT recommend 20-22 psi Max Boost and state that the AFR will be around 22:1.
Cruise Boost From what I am observing, I can confidentially achieve a 6-7 psi drop for cruise boost but I feel it is too laggy low down in revs. Question: Should I adjust the needle valve in the same manner as was done for the stock ecu as you advised?Thanks, JohnQuote:
open the needle until the turbo arm just floats off the adjustment screw..
It's a fine balance act that's for sure.
Try closing needle a little. It'll increase the curzing boost a bi t but also make it a bit perkier down low.
However have a look over the vacume system. Make sure all the hoses are in good order. When working with big boost you want full vacume to play with..
