Yeti's Beast
Can I just add something here. That battery is not sealed , back then Century didn’t have a sealed battery. They fitted a fake long cap over the actual battery caps. It’s hinged
If you lift it up with your fingers, you will see the 6 caps. Open them up and check the water level because a lot of these batteries run dry prematurely, killing them.
Century now have a proper sealed version but it still vents and should not be used in a confined space.
Agm, Gel or Lithium are the only safe options to be used inside a car/ caravan.
After 30+ years selling batteries I have learnt a trick or 2
Proud BTrol Owner
