1 Attachment(s)
The newest new member
Hey guys im in ipswich qld and get out every now and then but i have a strong passion for 12v electrical and minor mods accessory fitting and the like. I know theres plenty of places out there but if anyone needs a hand, jussaying dont mind helping out...
Attachment 79280
Hello and welcome to the forum.
Welcome to the forum mate.
Welcome to the forum.
Funny you should mention 12v accessory wiring, I'm just in the process of adding a boost/EGT gauge and dual battery monitor gauge to my GU III.
I'm planning on adding two fuse blocks under the steering column, soldering a wire to the 12v ON wire and Parker lights wire coming from the back of the ignition barrel to power each block, then a 2A fuse that can power and illuminate the gauges from the fuse blocks (as specified in the installation instructions).
So my question is; do you think it's fine to solder a wire from the wires on the back of the ignition barrel to power things like gauges, dash cams, stereo head units, etc?
I'm planning to use 50A 6mm auto cable from the ignition barrel to the fuse block.
Welcome to the forum mate and feel free to ask any questions.
Welcome and may I say just the I need,
mean while ask away and enjoy. Nothing goes unanswered
